Jan 29, 2020 3:11 AM UTC
Help please. Anchor Point not showing Premiere Pro
Hello all.
Admittedly not that experienced with Premiere. I just learned how to move the anchor point and why... but now I can't get it or the edge handles to show. I've tried selecting the clip (click on clip in timeline) and then double clicking the preview screen. I've tried clicking on Motion on the Effects panel. Nothing. I notice that Motion tab on the Effects panel does not have a square next to it, only an FX. In the tutorials I've seen, this box is shown on their screen. Incredible gratitude in advance... quite a frustrating experience over here.
R Neil HaugenCorrect answer
Jan 29, 2020 5:07 AM UTC
I still need to click on the individual graphic item in either ECP or EGP to get the bounding box and anchor points showing for that item.
Aug 8, 2021 4:24 PM UTC
pls help my ancor point showing the ancor point like the circle thing in the middle i could not find any tutorial so this is my only hope pls help.
Mar 14, 2024 8:13 AM UTC
If you are talking about the anchor if effect controls just click on it and look in the centre of your screan then hover your mouse on it  and make sure it shows up and down on your mouse then you can move it.
chall161Author
Jan 29, 2020 6:29 PM UTC
Thank you very much. This worked together with enlarging the preview screen. Many thanks.
Jan 29, 2020 4:57 AM UTC
I think the interface changed in recent versions; try just clicking on the word "Motion" under Effects Controls to get the bounding box with anchor point.
WM
-------------------------------------------------------------------------JVK | Editor/Designer/Software Instructor. Pr, Ae, Ch, Ps, Ai, Id
chall161Author
Jan 29, 2020 6:34 PM UTC
Yes, this worked. Thanks!
Jan 29, 2020 3:53 AM UTC
Are we talking about an anchor point for a graphic element? If so, you can click on that element's named line in either the Essential Graphics Panel or the Effects Control Panel. That should get the item selected on screen.
chall161Author
Jan 29, 2020 6:33 PM UTC
Thanks. I was working with pngs. I found that clicking on the bar next to motion in the effects control and enlarging the preview screen worked together. I was working from a laptop, so the preview screen was quite small.
