Help: Premier Pro no playback at all on M2 Max - not usable at all
I do really have an annoying problem which I hope to get fixed until monday.
I can start Premier Pro, but I can't play anything, not in the source window or in the program window. It just doesn't play anything. I can import videos, even cut them, but I can't play anything.
If I import videos or even if I try to in integrated premier pro test videos. Same issue
Mac Specs: M2 Max, 32gb, 1TB, Venture 13.6.2
Adobe: V 24.0.3 & V 23.6.2
I have tried several adobe version everytime the same issue.
Tested solutions:
- deleted any plugins
- delete media chache
- change audio device
- more ram for the app
- run adobe diagnose
- reinstall adobe
- try different adobe versions
happy for any help.
thank you
