Help!!! Premiere Pro not using GPU for playback or rendering, even with accelerated effects
  • January 28, 2021
  • 494 views
I have all the settings set correctly. I don't know why it's not using GPU. GPU would go up to 90% and GPU chills at 3%. As soon as I put on a LUT on Lumetri the playback stutters.
I can play all kinds of games and GPU would hit 80% 90%. What am I missing here?
AMD Ryzen 9 3900X
NVIDIA GeForce RTX 2070 Super
64GB Ram
Windows 10
 It would be nice to see your stats because I have an RTX 2070. You should be able to get it hit 80% usage if you have things setup correctly. I see a lot of problems with AMD CPU and Nvidia GPU combinations. Have you tried a BIOS update?
https://www.youtube.com/watch?v=1L-erwmRxAU&feature=emb_imp_woyt
Phuc.TranAuthor
Thank you for responding.
Yes I have everything set up for GPU acceleration, but it's just not working. I did overclock my GPU and it does cause some trouble with Photoshop and Lightroom, I'm not sure if Premiere is the same case. But I tried turning off MSI AfterBurner which usually causes problems for Ps and Lr but Pr is still not fixed. Can you show me your BIOS settings?
Sounds like a driver issue, download older version (like 456.71) from the NVidia site below and do clean install. Preferably studio version. And turn off all overclocking, GPU/CPU/RAM.
https://www.nvidia.com/Download/Find.aspx
