Help with audio settings for voice-over and music
- 11 replies
- 2883 views
- Translate
I edit documentaries for YouTube and I always mix the voiceover and the music separately. For the voice-over, I use the Multiband Compressor with the Broadcast preset and for the soundtrack, I use the Music preset on the essential sound panel and set it to about -12 dB lower than the voice.
I would like to know if there's an easier way to do this and automatize my workflow without mixing them separately.
Thanks in advance, I appreciate your help.
