_nicdean
Hold Shift to move Mask Points Vertically/Horizontally (broken)
  • May 10, 2024
  • 4 replies
  • 911 views
Day 1,076 of requesting Shift to work with Masks in Premiere.
  • Issue - Holding "Shift" does not lock masks points to move vertically and horizontally
  • Adobe Premiere Pro version number: 24.3.0
  • Operating system - Windows and macOS
  • System & Workflow details: Any sequence, any computer
Steps to reproduce
  1. Create a rectangle Mask
  2. Click on a single mask point or drag to select multiple mask points in Program Monitor
  3. Hold Shift and drag point up/down or left/right
Expected result
Mask point should lock to pixel-perfect horizontal & vertical movement
Actual result
Mask points "jump" several pixels and then lock to horizontal & vertical movement
Here is what happens when you try to move Mask points with Shift. A non-straight box.
Correct answer Ron Rigler
Hello @_nicdean, this is an error in the documentation. The SHIFT modifier option to lock to pixel-perfect horizontal & vertical movement is currently only available for the Shapes tool. We are looking at adding this functionality to Masks as well. Sorry for the confusion.
_nicdean
_nicdeanCommunity ExpertAuthor
Masks are being reworked in the Beta: https://community.adobe.com/t5/premiere-pro-beta-discussions/now-in-premiere-pro-beta-new-masking-tools/td-p/15484479
Please fix this feature so "Shift" works
Ron Rigler
@_nicdean is the issue with the way that the SHIFT+drag works in general or this is more about the selected point[s] offsetting when you click on them? With the new masking work that is now available in Beta, the issue with points moving when you click on them should be resolved. We are still working on adding support for SHIFT to contrain the drag. Hopefully you can take a look at the beta and give us your feedback. Thanks.
_nicdean
 With the current Beta 25.6.0, there is no issue with points moving when you click on them. But the Beta has no ability to Shift-drag. In the previous public versions of Premiere, these problems would occur together.
If you Shift+drag a point in public PPro, it jumps several pixels and then locks to vertical/horizontal movement.
Let me know if you need more info to fix
_nicdean
#innovationweek
_nicdean
@Ron Rigler thank you for acknowledging. Would love to see this feature added! A small quality-of-life update that would make a huge difference for users.
Ron Rigler
Ron RiglerCommunity ManagerCorrect answer
BrianLevin
Any updates on this? I'm on 25.2 and this still persists as an issue.
