Holding Shift to move clip and snap to another is no longer working
  • December 18, 2022
  • 486 views
I don't know what changed, but in the middle of editting a Seqeuence, I could no longer hold down shift to move a clip and have it snap to another clip. It isn't an issue with the snap not being on.
When I hold down shift now, it just locks the clip into place. I can no longer move it horizontally. Now it only moves vertically. I have reset my deault settings, trying different setups, even reinstalled,  but for some reason, it just stopped working. I can somewhat get it to work while holding down shift+ctrl, but I have never had to do this before and I can't find an reason as to why. It is like these weird things keep happing, but I am not changing anything that I am aware of.
Would anyone have an idea on what it could be or how I could fix it? I am on Windows 10
Peru Bob
Try resetting the preferences:
https://community.adobe.com/t5/premiere-pro/faq-how-to-reset-trash-preferences-in-premiere-pro/td-p/8236158?page=1
Reset a workspace
1. Do one of the following:
• Click the Workspace menu icon and select Reset to Saved Layout.
• Choose Window > Workspace > Reset to Saved Layout.
from here:
If that doesn't work, try creating a new project and import the old one into it.
Try Ctrl instead of Shift...........
Not either. It was just holding the Shift key. Ctrl doesn't snap.
Antonio Wimmer M
Hi! Did you find a solution for this?
