how activate audio scrub when using editing tools?(not the classic audio scrub when moving playhead)
  • September 4, 2023
  • 4 replies
  • 1988 views
Is there a way to activate audio scrub when using edition tools (triming tool, propagation tool, compensate ((sorry, it's a bad translation of the french names!)).
The "regular" audio scrub is ativated, when moving the playhead over the timeline, but I want to hear the scrub when I'm triming, especially with the "Moving cut Tool"(N shortcut).
I find the audio scrub really useful when triming, I've always use it with Avid and I miss it !
Thank you for your help !
Correct answer Ann Bens
N = rolling edit tool.
Unfortunately no.
This option is enabled in my settings... My question was not totally correct : I can hear the audio scrub when I"m in trim mode. But I want to know if it's possible to get it when I use the N tool (move the edit... I don't know the exact name in English).
I'm working on a multicam sequence and I'm in the stage where I praticly only unse the N tool, and it's a music video clip so I really need to hear this audio scrub. Is it possible ?
Thank you
Unfortunately no.
