How Can I Align Evenly Several Titles And/Or Objects/Images In Premiere Pro?
  • July 10, 2018
  • 33787 views
I have lists that I want to be lined up like this.
     One
     Two
     Three
But I don't always want them to be directly centered. I want flexibility to put them wherever I want. Many programs have an option where you can just drag the object or text and It will automatically align it and show you the spacing. How can I do that In Premiere Pro?
    Correct answer Averdahl
    Go to Window > Essential Graphics and select Edit. Select the text layers and play around with the Align and Transform options.
    Look for Align Left to align the text layers to the left.
    But, this will not work for images. For that and all of the abowe i mostly use After Effects.
    Averdahl
    AverdahlCommunity ExpertCorrect answer
    Gemma Dent
    All my options disappear as soon as I multi-select tracks, even if the tracks have exactly the same text/graphics elements on them. I believe the align and transform tools will only work if you're working on one track, meaning any other effects are not possible, you'll have to have all your text on one track.
    ___apoorva_verma___
    Yeah I have the same issue. Please can anyone help. As soon as i click multiple texts , all the options in Essential graphics disappears.
    You can use the featured format demonstration of above video without making it rolling credits.
