How can i create a rectangle with rounded edges as a title?
  • August 2, 2017
  • 8942 views
I can only do a rectangle or ellipse. Is there a way to change or modify the rectangle anywhere?
[Moved from the Lounge (which is where you can "connect with your peers" from across all of Adobe's products for conversations that don't directly relate to help and support) to a product-specific support forum by a moderator.]
    Correct answer jcourtial
    Well, how did you do it? Rounded rectangle shape in the Legacy Titler?
    I did it in Photoshop and saved it as a PNG. It was a lot easier than I thought it would be.
    John T Smith
    The Lounge Forum is not for technical help, please provide the name of the program you are using so your message may be moved to the correct program forum... A program would be Photoshop or Dreamweaver or Muse or Premiere Pro or ???
    jcourtialAuthor
    ha yes, don't know how i ended there as I was in the premiere forum originally! Thanks anyway, I've found the answer since.
    jcourtialAuthorCorrect answer
