How do I create a Control Surface plug-in using the Premiere Pro SDK (C++)?
  • March 3, 2024
  • 530 views
I want to create hardware that adjusts timeline and Lumetri Color using Premiere Pro SDK.
I'm trying to develop this plug-in, but there are no details in the document.
The document I read is
"https://ppro-plugins.docsforadobe.dev/intro/premiere-pro-plugin-types.html"
It is.
How do I get started to create a Control Suface plug-in?
Correct answer Bruce Bullis
From that page: https://ppro-plugins.docsforadobe.dev/control-surfaces/control-surfaces.html#control-surfaces-control-surfaces
Have you taken a look at the Control Surface sample?
Bruce Bullis
Bruce BullisCorrect answer
Yes, but the content is too lacking.
How do I connect my device to the plug-in?
Bruce Bullis
That info has been sufficient for every control surface plugin in existence, so far. 🙂
That process will be specific to your hardware device.
