How to add color grading to whole project
  • October 21, 2023
  • 1653 views
I am trying to color grade multiple clips but have been unable to add an adjustment layer even though I have selected the project pannel
Correct answer R Neil Haugen
Just for info for those who might not know yet ... you create an Adjustment Layer (AL) in the Project panel, New Item->AL.
Then drag/drop it onto your sequence. Adjust for placement/length.
Then select it, and you can add some effects like Lumetri to it. Not all effects are usable on an AL.
If you have a number of clips needing the same correction, doing it on one, copy and paste to all the selected clips in a Project panel bin applies the effect to all of them in one go. This is a "Source" effect use.
R Neil HaugenCorrect answer
MyerPj
What's it doing or what are you doing? Some screen shots might help, and the specific problem you're having might be a good starting poing. Also, Mac, PC, Win, version, PP version, etc... hardware info, clip info.
 This is what it looks like when I try to add an adjustment layer. I am using a Macbook pro with sonoma 14.0
MyerPj
Click on the Project panel before you click the FILE menu.
Or right-click the project panel and select "New Item" and then the adjustment layer.
