How to Add Mosaic Effect and Adjust Ellipse Mask Position Using ExtendScript in Premiere Pro?
Hi everyone,
I’m developing an ExtendScript for Adobe Premiere Pro and I need help with the following:
- Adding the Mosaic effect to a selected clip in the timeline.
- Creating an ellipse mask inside the Mosaic effect (like manually clicking "Create Ellipse Mask").
- Changing the position of the ellipse mask programmatically.
I’ve been able to access effects using clip.components, but I’m struggling to programmatically create a mask and modify its position.
- Is it possible to create an ellipse mask via ExtendScript?
- How can I change the position of the mask after adding it?
- Are there specific properties I should look for under the effect’s parameters?
Any guidance, sample code, or documentation references would be greatly appreciated.
Thanks in advance!
