How To Change Audio Pitch Without Changing Speed?
I am using Adobe Premiere Pro CS6, and would like to know how to
Increase or decrease the pitch of an audio file, without having to speed it up
or slow it down.
Thanks!!
or slow it down.
Thanks!!
A pitch-shift effect exists in Premiere Pro CC 2014. You can find it in the "Audio Effects" folder labeled "PitchShifter". You don't need to use Audition for this effect if you don't want to..
