How to close vertical gaps on audio tracks ?
  • May 19, 2023
  • 2746 views
The simplify sequence function can close vertical gaps on Video tracks,
but it does not work on audio tracks.
Is there any way to close vertical gaps on audio tracks ?
I assigned the keyboard shortcut of Ctrl+Alt+D to delete all empty audio and video tracks, it's great and saves me from having to run multiple commands.
But there is no empty audio track to delete.
For example
Cannot think of a automatic way.
Select a track (lasso or use the forward selection tool) then move them up (alt+arrow up)
