How to Consolidate Project in Project Manager with Mogrts to keep with project?
  • November 16, 2021
  • 259 views
Beginner here.
While consolidating my project via the Project Manager (to archive it), I noticed that one particular Essential Graphic I use on my timeline doesn't have a corresponding file in the Project bin. It's a lower third that uses an image. Only the image is contained as a file in the Project view, but the lower third itself doesn't have any media corresponding to it. There is also no aegraphic file for it generated. Now I am wondering how this is possible. How does this lower third get drawn when there is no media file for it whatsoever?
[Moderator note: title changed to more accurately reflect question to get better responses.]
Motion graphics ... mogrts ... aren't saved in bins. Unless you upgrade each to a "source graphic" from the timeline (or whatever they're calling them now). Which is a right pain.
To keep the mogrts with the archived projects, the mogrts need to be stored via the Essential Graphics controls in a Local Folder, and you copy the local folder into your archive project folder manually.
Joëlle Bh
Hello Florian
Do you have the latest premiere pro version?
