How to Create Edge Mask Effect in Premiere Pro Similar to Alight Motion
- 1 reply
- 1351 views
- Translate
Hi, I am trying to make the video style shown in the attached example. I know how to do this in Alight Motion but not in Premiere Pro. I will explain the steps I use in Alight Motion so you can understand what I am trying to do.
- I put the clip on Track 1 and the template on Track 2.
- Then I use the Chroma Key (Ultra Key in Premiere Pro) and use the black dropper to select the black area. This makes the clip show in the black parts.
- After this, in Alight Motion, there is a "Blending" option where I select "Mask" and then "Exclude Mask." This makes the white area transparent and automatically creates the edge mask. So, I get the clip styled with edges, and the white parts are transparent.
- At the end, I nest this and place the same clip in the background.
How can I do the same in Premiere Pro?
