How to create local cep extension for abode premier pro 2024?
  • October 12, 2024
  • 416 views
Help me with enabling cep extensions. I can't see them. The only extensions i can see are downloaded from stock market
Thank you!
Correct answer Bruce Bullis
If you're making extensions for PPro, I presume you're starting from PProPanel...?
Follow the instructions in the PProPanel readme, to enable unsigned extensions.
Bruce Bullis
Bruce BullisCorrect answer
kglad
<"moved from using the community">
