magoa32579342
How to customize exponential fade transition?
  • August 16, 2019
  • 1466 views
Hi there!
I noticed that the Exponential fade, when added at the beginning of the clip, increases the audio slowly then quickly. And when added at the end, it decreases the audio slowly then quickly. Can I change its behaviour so that it makes changes slowly and then quickly? What I want in the result is to imitate the constant power transition's effect for two clips which are on the different tracks.
Thanks in advance for the reply/ies!
Alas, they are fixed audio transitions.
I would drop them both on the same track and add Constant Power between them.
Peru Bob
Hi Ann,
magoa32579342 needs the audio to be on separate tracks as in this thread:
Constant power transition when clips are on different tracks
