Peru Bob
How to delete mogrt from Essential Graphics panel
  • May 4, 2024
  • 1405 views
Windows 10 Pro
Premiere Pro version 24.3.0 Build 59
I want to delete the mogrt named "delete" from the Essential Graphics panel.  As you can see in the screenshot, Delete is not available.  I can click on the Edit tab and rename it, but there is no option to delete.
The mogrt doesn't appear in Windows Explorer in any of the locations that mogrts exist, and I did a search for .mogrt and could not find it.
It is not located in my library of assets when I go to my account online.
I don't have sync enabled, and the computer is disconnected from the internet.
Backstory:
It was originally named Slow Fade On, but when I created it in After Effects, I forgot to allow a few properties to be modified in Premiere Pro, so I opened it in After Effects, added the properties I needed, and saved it.  Instead of writing over the existing mogrt, it just created a new one of the same name.
So, how can I remove it?
Correct answer Ann Bens
You can delete from your Libraries panel.
Peru Bob
Peru BobCommunity ExpertAuthor
Update:
I don't know why, but when I changed the name back to its original name in the Essential Graphics Panel, it appeared in My Library.
I was able to delete it from there.
What I learned from this:
When importing a mogrt, an aegraphic file is created locally.
The images in the Essential Graphics panel are shortcuts to the aegraphic file, not the mogrt file.
So it seems that Ann Bens was correct.
Peru Bob
Thanks, Ann Bens.
I'm not at my editing computer now, but will do that when I am.
