How to entirely deselecting audio tracks on source in Premiere Pro
How to entirely deselecting audio tracks on source in Premiere Pro.
I want to edit a clip that has 16 audio tracks, but I want to use only 2 tracks audio out . I only have two tracks in the sequence, so the timeline in the source shows two tracks as well, but it also adds a small plus sign, which when you press it shows all 16 tracks, Then you can uncheck all the tracks by clicking on any track with a shift button, Premiere creating those tracks in the sequence as well.
and after this operation I have to delete also unnecessary tracks from the sequence.
Is it possible to disable tracks from the source without unrolling the all audio tracks ?
Wojtek
