How to export media with project name
Hi
once I finish editing I have various clips on my timeline.
I select the time line and attempt to export the MEDIA
1st question
The default output name is always a clip name example MVI_1234.mov
Is there a way to tell Premiere to set as a default outputname the projecy name?
Using a clip name is confusing and i need to manually select the output folder and change the name manually this is very time consuming
2nd question
I created a default output which includes PRORES 422 and various other choices
Is there a way to set this output as the default output so I donàt need to manually select it each time
I ask these questions as I had to manually change every single edit from version 2015 to version 2018 and I need to edit each film sequence separatley for my feature.
I found no systems to automatically open in CC2018 although the single clips are in the same disk and folder and each time I had to link them again.
If anyone would kindly help this will be wonderful
Thanks
