How to export the Hightest Audio Quality (16-24bit) ?
  • March 27, 2018
  • 50978 views
What is the settings for export the best quality audio in Adobe Premiere Pro ?
I work with 16bit and 24bit FLAC files, I have to use the same settings for both?
i have already make a preset but i dont think this is completely lossless :
Honestly i don't think premiere pro can render audio lossless
Please Help me.
Note : i dont care if the final is 30GB, i want the maximum quality, Thank you
Correct answer excited_Genie16B8
this is for YouTube,
In that case, choose QuickTime as the Format and GoPro Cineform YUV 10 bit as the Preset.  On the Audio page, you can change from 16 to 24 bits.  (48 kHz is fine.)
Hi
Based on your screenshot, you have to use Uncompressed / 96000 Hz / 32bits float, to get the best possible audio quality. But, depends on where do you go to play it to run nicely.
Regards!
Byron.
March 27, 2018
Thank you, this is for YouTube,
i try to get the best quality like audiophile and professional channels (example : Vevo)
I do not know what software these people use, but I really want to know.
OH, it's for YouTube. In that case it is not necessary so much quality that the only thing that will do is increase the weight of your video file because when uploading a video on YouTube, it transcodes and compresses your file in several resolutions, that is, it does not maintain the original quality as we would like.
In that case with these configurations are enough:
Regards!
Byron.
Choose Wave under Format.
March 27, 2018
Oh you mean Wave instade of Quicktime ?
Yes.
