How to fix " adobe premier pro.exe has encountered a problem and need to be close "
  • October 13, 2021
  • 1777 views
Hi
can  someone help me i'm facing this message when i want to launch premiere pro application. apprently its effected as well with my After Effect, Audition and Media Encoder but illustrator and photoshop is working.
Hey bro have you succeeded in fixing this error if yes then please tell me the solution too, I am experiencing the same error.
Expecting your instant reply
Kartika Rawat
Sorry about the issue. When exactly does Premiere Pro crashes? Can you check crash reports here? You can also try some suggestions mentioned in this article: https://adobe.ly/3IlWewy
Let us know if this helps.
KR
Might need to tackle this at the root: start with reinstalling OS.
