How to fix inconsistent chronological order when creating sequence from Project Panel clips?
Hey all,
I’m trying to find a reliable way to lay clips from a bin into a sequence in strict chronological order, and I’m running into inconsistent behavior.
My typical workflow:
    •    In the Project panel, I switch to List View
    •    Sort by Creation Date (ascending or descending depending on preference)
    •    Select all clips in the bin
    •    Either:
    •    Right-click → New Sequence from Clip, or
    •    Drag them into an existing timeline
The issue:
Sometimes this works perfectly, but other times:
    •    A random clip gets placed at the very beginning or near the start
    •    Or the entire sequence comes in partially out of order
    •    Occasionally it even seems reversed
I’ve tried:
    •    Clicking the first clip vs. last clip before creating the sequence
    •    Dragging from top vs. bottom of the sorted list
    •    Using both ascending and descending sort orders
None of this produces consistent results.
What I’m trying to achieve:
A dependable way to take a bin of clips (sorted by Creation Date) and have them land in a sequence in exact chronological order every time, with no manual fixing afterward.
Additional context:
    •    I often use “New Sequence from Clip” so the first selected clip defines the sequence settings
    •    I have “Set to Frame Size” enabled in Premiere settings, so mixed orientations (horizontal/vertical) display well. I use widescreen sequences, and vertical clips are automatically resized to find inside them.
Main question:
Is there a known reliable method to ensure clips are laid down in the exact order shown in the Project panel?
Or is this just a limitation/bug in how Premiere handles multi-selection + ordering?
Appreciate any insight, folks.
    Averdahl
    ​@Jeena22389650a1ho
    I think it is a combination. Premiere has a bug when sorting clips in bins when other letters than A-Z is being used. For example, i live in Sweden and we use the letters Å, Ä and Ö and Premiere fails to sort those letters correctly. In the example below it sorts them the way you can see in the image below while the correct way is A, B, C, Å, Ä, Ö. It sorts them wrong the other way around as well. This is bad 2026.
    So if any letters outside the A-Z range are used the sorting will be a mess and placing selected clips in a timeline will be a mess as well if one is unaware of this. But, it can be a mess using A-Z as well but in some way more “controlled”...
    And even if one leave Å, Ä, and Ö out it is prone to issues as well when selecting the clips and laying them down on the timeline. As ​@Ann Bens mentions 1, 2, 10, 11 can sometimes become chaotic as well. I did a small test now but everything worked, but i had issues some days ago with some clips i had not renamed to 001, 002, etc, etc. That shows the inconsistent behavior right there.
    Make sure your selection does not include any bins. Including bins can cause Premiere to ignore your sort order and instead add clips to the timeline based on import order.
    A reliable workaround is to select your clips in the Project panel, then go to Clip > Automate to Sequence. This dialog gives you control over clip ordering, allowing you to choose between Sort Order or Selection Order before the clips are added.
    Most of the time this works.
    But if it does not, I lasso sections from the Project Window at a time and drop those in the timeline.
    I found if images are named 1, 2 , ….,9  and then followed by 10, 11, ……. it becomes a mess.
    I rename everything to 001, 002 etc.
