How to fix muffled audio in Adobe Premiere?
  • December 21, 2017
  • 4 replies
  • 25704 views
I know some people have had this problem before, but I can't seem to fix it.
When I Import an .avi Video with voice over, the Voice Over sounds muffled.
But the background music I add sounds fine.
When I delete the Voice Over track and add it as either .mp3 or .wav, the Voice Over is even more muffled.
What can I do?
Thanks for your help
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
[Comments is to ask about the operation of the Forum, not a specific program]
[Moved from the Comments forum to the specific Program forum... Mod]
FOUND THE SOLUTION:
Premiere Pro>Preferences>Audio Hardware and make sure the sample rate is set to 48000 instead of 16000. This solved my problem with audio playing back distorted and muffled.
tomk15878240
I figured it out - Under View > uncheck 'Use Optimized Clips'.
i couldnt find the 'view' menu besides all my other menus such as windows and edit. is there other places where i can find the 'use optimized clips' box?
Dont think that is an Adobe product.
Warren Heaton
Can you include a screen shot of the audio levels In the Source panel?
Honestly, the only suggestion I have is to record it properly.  I'm not sure "muffled" is something you can fix in post.
sven2911Author
You don't understand. The audio file is fine. Its only a problem when its in premiere.
sven2911Author
This is not something we're seeing reported by others.  I can only think it's a problem on your system.
You can try Steps 2E and F below.  Report back.
Unofficial Premiere Pro Troubleshooting Guide
I already started a new project a few times. And this is a complete new install of Premiere.
No Plugins, no settings changes.
I thought I read other reports of similar issues though.
Could it be something really simple, like in the settings for a new project maybe?
Or could I try different file formats? As I said I tried .mp3 and .wav so far.
