How to fix muffled audio in Adobe Premiere?
  • December 21, 2017
  • 4 replies
  • 25702 views
I know some people have had this problem before, but I can't seem to fix it.
When I Import an .avi Video with voice over, the Voice Over sounds muffled.
But the background music I add sounds fine.
When I delete the Voice Over track and add it as either .mp3 or .wav, the Voice Over is even more muffled.
What can I do?
Thanks for your help
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
[Comments is to ask about the operation of the Forum, not a specific program]
[Moved from the Comments forum to the specific Program forum... Mod]
FOUND THE SOLUTION:
Premiere Pro>Preferences>Audio Hardware and make sure the sample rate is set to 48000 instead of 16000. This solved my problem with audio playing back distorted and muffled.
tomk15878240
I figured it out - Under View > uncheck 'Use Optimized Clips'.
i couldnt find the 'view' menu besides all my other menus such as windows and edit. is there other places where i can find the 'use optimized clips' box?
Dont think that is an Adobe product.
Warren Heaton
Can you include a screen shot of the audio levels In the Source panel?
Honestly, the only suggestion I have is to record it properly.  I'm not sure "muffled" is something you can fix in post.
I'm having the same issue and it has nothing to do with the quality of the audio. The audio is muffled across software for as long as Premiere is open and running. Even when I try to play an album on Spotify, the audio is still muffled. This is an issue with the Premiere software, not the clips being used.
Kevin-Monahan
Exactly! Same thing happening to me. It effects all programs. Makes no sense at all...
Dear ReeceD,
Sorry for that. How odd!
Show us a screenshot of your Audio Hardware preferences. That could help us diagnose the issue.
