XilburQost
How to load an effects preset?
  • March 19, 2023
  • 1914 views
I just created a complicated Lumetri Color effects preset and saved it. Problem: I want to load this preset into another Premiere project file, but I cannot find any option for doing this.
I found an online guide that says you should click on the hamburger menu next to the Effects control and click on "Import Presets", however, there is no Import Presets option there.
I've looked elsewhere in Premiere, but I cannot find any option for loading or importing Effects presets. This should be easy, right? I'm pulling my hair out. Any suggestions? Thanks.
Premire Pro 24.2.1, Windows 11
Correct answer Averdahl
quote
...next to the Effects control and click on "Import Presets", however, there is no Import Presets option there.
By @XilburQost
Presets are imported in the Effects panel, not the Effect Controls panel. 🙂
quote
By @XilburQost
There is no such version (yet).
XilburQost
My bad. That's the Photoshop version. Premiere is 23.2.
Averdahl
AverdahlCommunity ExpertCorrect answer
quote
By @XilburQost
XilburQost
Thank you! (I found the preset as it was added to the Preset menu).
