How to make adjustment layers smart?
- January 18, 2022
- 3 replies
- 716 views
Hi, guys. Is there any way to make adjustment layers smart in premiere pro? I'l describe my problem:
I have a sequence consisting of 2 video tracks. The footage is already chopped into pieces and lined up. It's a footage with a talking head (1st camera shooting the overall view, the 2nd - picking details). At some place of the sequence I want to make a color corrected picture-in-picture footage (the detailed picture as a fullscreen and the overall view of the speaker as a square picture in the right-hand corner of the screen). Both the tracks have a color corection adjustment layers above them so the video in the square gives its colors to the full screen video. To solve this problem I usually make a mask in the adjustment layer or just place it with the video itself into the nest. But it's a way time consuming when you have 50 or 80 such pieces in your footage. Is there a simpler way to make an adjustment layer influence only what the track shows and not all the tracks beneath it? Maybe some opacity exclusion or matte-things?
