How to Make "Fit" Program Frame Horizontal
I am a premiere novice. I need help.
As I edit, I want to create text and add images so that the way they look on the program panel screen is the exact way they it will appear when exported to the final product. I'm assuming then that I should be working with the frame in "fit" mode, but when it is, the screen is veritcle. I want the black part to be horizontal, and I want it to be this way when exported. Any help is greatly appreciated.
