How to move all clips to the left after I cut section out?
  • September 5, 2021
  • 25151 views
Hi all,
Know really simple question, but struggling to find a simple answer.
I've got lots of video clips that I'm putting in the Premiere timeline and, as I'm now editing them, I'm frequently having to cut out sections and then shift select every clip to the right of it and drag it to the left to fill the 'gap'.
Pretty sure there'll be a much smarter way to do this from a pro....!
Whilst I'm asking this, I quite often have the reverse - ie I realise I need to insert a video somewhere and need to move all the clips to the right. It's annoyingly been overwriting existing video clips if I drag them into the timeline without any warning message.
Any tips very welcome!
Correct answer Ann Bens
When moving the clips hold down ctrl+alt until you are ready to drop them on a different part of the timeline.
Shivangi_Gupta
Hi there,
We appreciate you writing in and hope that you got answer to your query. Give us a shout if you get any issues.
Shivangi
Dave5E20Author
Brilliant - thanks all!
Rag and Bone
Have a look at this article, especially the section on ripple edits.
