How to reactivate Blackmagic RAW filter??
- December 22, 2023
- 4 replies
- 4638 views
I desperately need help.
I'm working on a project with Premiere 2024 on my Macbook M1 Pro running Sonoma 14.1.2. Some of the used files where BRAW files and everything was OK so far. I was able to work and color grade my BRAW files with lumetri.
Then I was trying to open two projects with BRAW files at the same time and that's where Premiere was giving me error messages. Premiere then offered me to deactivate the Blackmagic Raw filter, and I pressed OK. I assumed I could re-activate the filter later and do some quick changes without BRAW for a few minutes.
Now, when I open my file I get a message (in my German version), which translated means: "Videofilter is missing: Blackmagic Raw". I am able to see my raw files within the project, but they look completely different now, like very flat log-footage. I have looked everywhere in Premiere, in forums and in my system, but I can't find any way to reactivate this plugin/filter.
So what I tried next to reinstall Blackmagic Raw in the newest version 3.6.1. No change. I deinstalled and reinstalled. Restarted my Macbook several times, no change.
I'm quite desperate, because I need to deliver this project. Any help out there?
