How to save Premiere Pro Project in Creative Cloud?
  • September 29, 2020
  • 62437 views
    I usually work the project on my laptop at home, but these day I hope I'm able to work on my office computer when I have free time during workday.
    So is there any way that I can save the project file in the creative cloud and then open the file up in another computer with creative cloud? And do I also need to backup all my video files I have used in the project?
Correct answer Kevin-Monahan
You can also set the Auto Save preference to save a copy of the project file in your Creative Cloud folder.
Kevin-Monahan
Kevin-MonahanCommunity ManagerCorrect answer
Odobe
Hi @Kevin-Monahan
How are you?
We have multiple users in our office and some of us are able to click the "Save backup project to Creative Cloud" and for others it is greyed out. Do you know why it might be greyed out for some?
Kevin-Monahan
Hi @Odobe,
quote
I'm not sure. Let me try to find out. It still might be available in the interface, but saving to Creative Cloud was shut down on Feb. 1 unless you're a Teams or Enterprise (or Educational) user. Are you on Teams or Enterprise? Please let me know. Sorry for the issue.
If you have all of your assets in the same folder structure and you move that entire folder, Premiere should detect the assets again on a new machine.
My project folder structure looks something like this. When I move the entire top-level folder, everything relinks with no issue, regardless of the machine. And if you do have to relink, you should only have to relink one clip and Premiere will find the rest since the location relative to the project file is the same.
  • Project Name
    • Assets
      • Audio
      • Fonts
      • Graphics
      • Notes
      • Video
    • Encodes
      • Master
      • H.264
    • Project Files
      • After Effects
      • Audition
      • Character Animator
      • Cinema 4D
      • Premiere Pro
        • Premiere Project File
Saving anything to your Creative Cloud folder is just like using Dropbox, OneDrive, or other type of cloud file storage service. In your user folder (both on Windows and macOS) there is a folder called "Creative Cloud Files." You can put your entire project folder in there and it will sync with another machine that you're logged into the Creative Cloud Desktop application with the same Adobe ID.
And yes, you need all assets you're using on one machine to be on the other. One way to keep things simple is to have a duplicate of your project structure on both machines, then just sync your .pproj file back and forth. This will only work if you're not adding any new assets to your project or changing the folder structure on your disk. If you have enough Creative Cloud storage for this project then you can leave the entire project folder in your Creative Cloud folder and work from there on both machines.
I have the same question, but I have all the assets for my project on a USB drive. Does this improve the situation?
Creative Cloud storage is sadly no longer available, so I don't think this will work anymore. I see the option is still in the software, but I think that's because enterprise plans still have the storage feature for a bit longer before it's discontinuted. If you want to sync your project, you'll have to use another cloud storage system. You will likely have to relink your footage each time, even if it's on a USB drive unless the computer username is identical and the external drive letter is the same on both machines.
