How to turn off Multiple Projects in Premiere pro?????!?
  • June 3, 2021
  • 2326 views
Hello!
I dont like the feature opening multiple projects..
I find it VERY messy and make mistakes very fast..
Is there a way to turn this off?
Adobe is forcing me to use the multple projects.. I Dont want this at all!
Mod: It is against our community guidelines to condone the use of internal debug tools. These are not meant for customers to use. Comment has been removed.
Toldorn
I'm in the same boat. It's frustrating as hell.
Also, Averdahl, changing 25years of muscle memory to ''simply close project a before opening project b'' isn't helpful.
Kevin-Monahan
File > Close All Projects is what I use. You get used it.
Toldorn
I jusst bought a copy of Davinci Resolve... To quote your piss poor support ''I'll get use to it''.
Peru Bob
Averdahl
The easiest way i am aware is to only use one project at a time. If i open Project A and need to make a change to Project B i simply close Project A and open Project B and when done, close Project B and open Project A again. By doing this i only have one project open at a time. It´s a workflow thing. Ignoring to close projects and just open up project after project is a recepie for problems, at least for me and that´s why i always avoid it. 🙂
The direct answer is: As far as i know there is no Preference setting to stop the end user from opening multiple projects.
