_keyframer
How to undock the Audio Meters panel
  • March 9, 2025
  • 750 views
Sorry but the fact I can't close the Audio Meters panel or even undock it in an effort to close it is frustrating. Yes, I searched the forum and all I see is how this is still a bug after many years. I found a "solution" to hover over the blue line indicating the panel is selected and holding the Ctrl/command key and undocking it but I have tried numerous times with no ability to undock it.
For at least a year after an update the hot tect slider for the X and Y positioning is SLOW! Even with a simple text field, moving it into any position has crazy lag. I'm on a MacBook Pro M1 and Premiere is just so slow.
Due to a client project I had to use a much much cheaper and popular alternative with so much success, I'm starting to think Premiere is in my rearview mirror after over a decade of use.
What's happening Adobe? Adobe Animate being completely ignored for over a year and now Premiere falling so far behind in so many ways for me. Sorry for the rant - just glaring issues from a devoted long time user 😞
Correct answer Warren Heaton
@_keyframer
I'm not sure anyone could fault you for thinking, "Wow, this could be easier."
I've found that the Audio Meters panel needs to be set a little wide in order to get the mouse to incidate that we're in the right spot to right-click and close it.  If it's too narrow, we won't be able to close it.
Warren Heaton
@_keyframer
The panel options for Audio Meters are a little tricky to find, but they are there.
Here's a screenshot to add to what others have already mentioned.
Animate does seem to be light on new features, but Rig Edit Mode in 23.x was a pretty big.  Of course, Animate 24.x being Apple Silicon native was pretty big on the macOS side.
As far as the 2025 releases go, I think Illustrator may have been the leader of the pack when it comes to exciting new features.
_keyframer
thanks!
Animator and content creator for Animate CC
MyerPj
Or unselect it from the Window menu.
To close the Audio Meter panel, right-click the top of the panel (just below the blue outline) and select Close Panel.
_keyframer
I tried that so many times - could be the resolution of my screen forcing me to be extremly precise with my cursor positioning
Warren Heaton
Warren HeatonCommunity ExpertCorrect answer
@_keyframer
