ConsfusedUser
How would I make a long, slow transition, blending the lighter parts of a shot in first?
  • July 5, 2024
  • 485 views
I've got two shots that I need to slowly blend together over the course of a few seconds. Currently, I'm envisioning a transition where the lighter parts of the second shot are slowly blended in while the first shot slowly dims to reveal the darker parts.
Here's the two different shots:
I've also got After Effects, if need be. Any suggestions are appreciated.
Correct answer PaulMurphy
You can create a long, slow transition by using the Film Dissolve transition, which automatically blends the lighter parts of the shot first.
For more control over the transition, try using the Gradient Wipe effect found in the Video Effects > Transition folder. This effect allows you to fine-tune how the transition progresses.
Cheers,
Paul
PaulMurphyCommunity ExpertCorrect answer
Cheers,
Paul
ConsfusedUser
Thanks Paul, I'll give this a try
