Cee.Zee
i can't move mask with arrow key
  • December 14, 2020
  • 14 replies
  • 7036 views
I can't move seletion mask with arrow key it a bug or i turn something off?
everytime i hit arrow key it move playhead in timeline
even i already select mask it still move playhead instead
and i already check keyboard shortcut
Correct answer Gabriel30532191cl8u
Very anoying...started happening to me right now, April 2024....by the morning it was working fine, but now every time I create a mask at opacity of any object, it can be psd, png, or nested sequence, i cannot move the mask. It just creates new mask points. By the morning was everything fine, I stopped for lunch, came back, and then this suddently started to happen. I even did not close premiere between lunchtime. Very anoying and it seems to not have a solution.
Update: Seems it is related with the size of the mask in the object....if the resolution is too small, mask cannot be moved
Gabriel30532191cl8uCorrect answer
DaveRizzWork
omg, Omg, OMG it's WORKING! It's BACK!
Is anyone else seeing the fix in the latest update to Premiere? It updated for me today, and it sure looks like point modification via Arrow Keys is BAAAAACK! Even the Shift+Arrow Keys is working too!
Thank you Adobe and @Kevin-Monahan !
Kevin-Monahan
You're welcome. I'll let the team know too.
allyhv
Anyone has any news on this? I've been having the same problem. Version 15 didn't fix it.
Kevin-Monahan
This may take awhile, Ally. The "to do" list for these folks is long! Sorry. I will do my best to bump up the status of the bug I filed. Thanks for reminding me.
allyhv
Thank you for the quick reply!
GingerSnap70
Has there been any progress on this issue? It is driving my bonkers (language adjusted to PG rating...).
DaveRizzWork
Not that I've seen. No relevant updates that have fixed anything related to this that I've seen.
Adobe employee @Kevin-Monahan saw this thread and submitted an internal bug report on 2/11/21... so hopefully something will come through on the next update?  FingersX
Kevin-Monahan
Dave,
I have an update. Turns out my bug was a duplicate and had already been reported by editors in Japan. Others are hitting the same bug, so the good news is that the bug predates mine. That means the issue is farther along and is definitely being fixed as we speak.
Thanks again for reporting this issue.
I posted about this on the Adobe Premiere subreddit.
https://www.reddit.com/r/premiere/comments/kbav8l/using_arrow_keys_to_move_a_mask_no_longer_works/
No response.
I got so fed up I tried calling customer support where I was on hold for 3 hours. They told me they would call back soon with a solution. They never did. That was weeks ago now. Absolutely infuriating.
DaveRizzWork
Yeah, that sucks... it's great that we get to pay for that stellar customer service for the rest of our careers, right?
Cee.Zee
Cee.ZeeAuthor
Another update but still not fix 😞
DaveRizzWork
Yes. I've been having this same problem and it is a complete PAIN IN THE ARSE! WhenTF is Adobe going to fix this problem???? I've tried changing the keyboard short-cuts, turning on and off Multi-Cam, and any number of other "solutions" people post in Adobe and on Reddit, and the web.
C'mon ADOBE! Get this fixed already. There have been like 2 Premiere updates since I noticed this bug!
DaveRizzWork
TheRealTopherG
Bump for help... havent found a fix.
Rolling back to a previous version doesn't mean this is "solved." If it's a bug, Adobe needs to fix it. If it's a removed feature, they should inform.
