I have problem with the audio output when I switch from headphone jack to speakers there is no audio
  • April 4, 2023
  • 478 views
Hey Maysam,
Are you on Mac or Win? check your Audio default Output setting in Preference.
Suraj Shinde.
I'm on Pc I check the Output its ok with all softwares only the problem
with premiere
Kevin-Monahan
Hi maysam,
How annoying. Can you check out this tutorial that steps you through the process. Does that work for you? Sorry for the frustration.
