I need help removing audio background noise from video clips.
  • November 14, 2023
  • 198 views
I could use some pointers or pass it to you and I will pay you. Please get back to me. Thank you!
Mod note: personal info removed.
Hi @Jeff33587712xg02,
Have you considered Premiere Pro Beta's new Enhance Speech? It may be just the thing for you. Otherwise, try the Denoise effect. Hope one of those works for you.
