Oct 18, 2025 5:48 AM UTC
I need to work! What's going on? What's the problem?
These windows appear and the sound disappears.
Warren Heaton
Oct 18, 2025 6:37 PM UTC
Hi @Paul_Gringo:
Yeah, frame substition errors can be very frustrating.
What is your source footage?
I would try transcoding it to Apple ProRes 422 LT or Apple ProRes 422 HQ using Shutter Encoder (dontationware - free if you set the donation slider to the left on the download page), and then right-click the videos in Premiere Pro and use Replace Footage to swap the current files for the transcoded ones.
Oct 19, 2025 7:31 AM UTC
I don't have time for this. Why do all other editing programs work fine, but here I have to spend my time for transcoding ? Maybe it would be better to do a NORMAL update at least once!
Intel Core i7-14700K 3.4GHz/33MB s1700 BOX MSI MAG Z790 Tomahawk Max Kingston Fury DDR5-6400 65536MB PC5-51200 be quiet! MSI PCI-Ex GeForce RTX 5070 Ti Gaming Trio OC 16GB GDDR7 SSD Samsung 990 Pro 2TB M.2 PCIe 4.0 x4 NVMe 2.0 V-NAND 3bit MLC SSD Samsung 990 Pro 1TB M.2 PCIe 4.0 x4 NVMe 2.0 V-NAND 3bit MLC Toshiba MG Series Enterprise 20TB 7200rpm 512MB MG10ACA20TE 3.5 SATA III Windows 11 Pro 25H2
Warren Heaton
Oct 20, 2025 11:35 PM UTC
Why should we have to spend our time transcoding is a very good question.  The format that our device records or the format that we've downloaded may be a good format for playback, but that doesn't mean it's a good format for editing.  Sometimes transcoding is just a good troubleshooting step.
Here's a list of file formats that are supported in Premiere Pro.
https://helpx.adobe.com/ie/premiere-pro/using/supported-file-formats.html
If the format you're using is on that list, Premiere Pro should at least be able to import the file; however, for smooth playback and good editing performance, that can depend on whether our workstation meets or exceeds what's require for the corresponding format.
Transcoding isn't unique to Premiere Pro.   Other NLEs like Media Encoder, Vegas, Resolve, Final Cut Pro each have a list of supported file formats and hardware requirements.  While Premiere Pro calls formats that shouldn't need transcoding "Smart Rendering formats", some other NLEs refere to them as "Optimized formats".
