Jun 26, 2025 4:05 PM UTC
Imported clips to Premiere Pro 2025 have static (white noise) in audio tracks
I shot video using a Sony NXCM HXR-NX3 camera. It plays back perfectly in Windows Media Player. When imported into Adobe Premiere Pro 2025, the audio tracks are nothing but a constant level of static (white noise). I've never had this problem before. It does this in both 2025 and Beta. Attached is a screen shot of my audio hardware settings. Any help is greatly appreciated.
Sumeet_Kumar_ChoubeyCorrect answer
Adobe Employee
Aug 29, 2025 11:38 AM UTC
Hi everyone,
This issue has been fixed in the latest release of Premiere Pro (v25.4), which can be installed through Creative Cloud Desktop app.
Sumeet
Adobe Employee
Hi everyone,
Sumeet
danm32376722
Jul 24, 2025 12:22 AM UTC
Same issue here. Reverting I guess.
Adobe Employee
Jul 24, 2025 3:34 AM UTC
Hi there,
Sorry about the poor experience. We've made progress & are working on getting a fix for this issue out in an upcoming release as soon as possible. We'll update this thread as soon as we have more details. For the time being, you may use Pr v25.2 as a workaround.
Thanks for your patience!
Sumeet
Jun 26, 2025 4:52 PM UTC
This is widely discussed in the forum at this time, many posts on such things with Sony meda. Which is most often mts, it seems.
The suggestion from staffers is to revert to 25.2 for now, as they are working on a fix to be released in the next patch update.
Jun 26, 2025 5:50 PM UTC
OK, thanks for the guidance!
