anthonyc47215134
Importing Markers to Premiere Pro 2020
  • June 26, 2020
  • 10540 views
PP 2017 has a bug where when you save to a newer version of PP, like 2018 or 2020 it does not carry the markers over with all the transcriptions.  I've assigned these markers to individual video files that I've already imported into Premiere Pro and as a workaround I exported the markers from the older version of PP 2017 as CSV files but there is no way to import them?  How is that possible.  Is there a solution where I can import my CSV files with teh markerker data and assign them to their respective files?  Please help.  It took me weeks to transcribe all of this info.  Why can you export but there is no obvious way to import?
Correct answer PaulMurphy
You can use this free website to convert CSVs, XMLs, etc. to Markers in Premiere Pro:
https://en.editingtools.io/marker/
The import of markers can be achieved via the SRT format, please see the youtube video
https://www.youtube.com/watch?v=C_7h50LL_ZQ
Sightsofsound
This video is in German. Anyone got any answers in English.
Thanks
PaulMurphyCommunity ExpertCorrect answer
Markerbox Man
I know your question is 10 months old but, as nobody has ever replied, I will still answer it:
There is now a free extension for Premiere Pro that can re-import markers that have been exported to a CSV file using Premiere Pro's native marker export. Check it out at http://markerbox.pro
It might be too late for your project, but it might help others struggling with similar tasks.
goaskerin
I have the same problem as hobsonfeltus - Markerbox shows up in the extensions menu, but it doesn't launch. Running macOS 12.6 and Premiere Pro version 23 build 63. I would LOVE to make this work!
Sorry for the very late reply, but I've only started looking into Markerbox today.
I ran the following command in terminal
find ~/Library/Preferences/ -iname 'com.adobe.CSXS*'
It showed I had 2 versions of CSXS installed.
/Users/#/Library/Preferences//com.adobe.CSXS.11.plist
/Users/#/Library/Preferences//com.adobe.CSXS.10.plist
By ammending the instructions to the following.
defaults write com.adobe.CSXS.11 PlayerDebugMode 1
I was able to get the panel to show up in Premiere correctly. Hope this helps!
Exact issue and that got it / permission has to point to the CSXS.__ you have.
Thanks Jesse!
