Jan 29, 2012 4:39 PM UTC
Importing .mts AVCHD video into Premiere Pro CS5.5, HELP!
I am new on Adobe forums and I nedd a question answered.
I have seen that there is no definite answer on how to import .mts files from my Canon Vixia HFR20 to Premiere Pro CS5.5.
I get "The file has an unsupported compression type" message. For now I convert the videos to .AVI but i would why would I continuosly convert them?
I bought the camera mainly for the HD, so help soon would be greatly appreciated!
Thanks in Advance,
Ethan
P.S: I have a PC to put that in mind...
WolCarlos
Dec 30, 2018 10:36 AM UTC
Adobe Premiere 2018 supports .MTS files.
To avoid problems with the RAM you have to remove the files you want to put on premier from sub-sub-sub-folders, example:
YES: Movie.mts ----> move ------> to D: \ Movie \
NO: Movie.mts ----> move ------> to D: \ Movie \ SD \ File \ local \ Movie file \ HD \ because all these folders \
Jul 16, 2018 12:46 PM UTC
Not sure if this is too little too late but I saw that this thread still gets a lot of views. With most Canon cameras the easiest thing to do is use the Data Import Utility that the camera came with. Connect the camera to the computer and run the utility to automatically import the AVCHD (as .mts). Not only does it do it for you but if you have a camera that breaks longer scenes into small bits it will "stitch" them together while importing. Then just bring the .mts file into Premiere. Hope this helps.
Just a note too the Utility is now hosted by Pixela in case you dont have the cd and search the web to download it.
sunderlandgreen201503
May 24, 2017 7:58 AM UTC
I would suggest sourcing the higher level files if possible, and retaining the original file structure.
If you can't source them, at least bring in what you have via Media Browser. Sometimes where a single MTS take has spanned across two clips Premiere will import two files into the project that are the same exactly. Just double check they are they same and you could remove one if it bothered you.
Editing with MTS and movs will be fine, however to make Premiere work as smoothly as possible be sure to set your editing timeline to the format that the majority of the clips are in. For example, if 90% of the media is MOVS then grab one of the mov clips from the project bin and drop it onto the 'new sequence' button in you project panel and a new sequence will be created that will be set for optimized editing of MOVS.
anim84792502
May 28, 2015 12:51 AM UTC
This worked for me, and is a very quick solution from Adobe: Importing AVCHD media into Premiere Pro on Mac OS X v10.8 (Mountain Lion) | Premiere Pro work area
Jan 6, 2015 2:34 PM UTC
I'm having the same problem with Premiere Pro CC 2014 and moving the entire AVCHD will not solve this issue.
This issue is big as most modern camcorders now record in the .MTS format, and I for one don't want to resort to having .mts files be transcoded files into other formats.
Jan 6, 2015 3:10 PM UTC
Besides copying ENTIRE contents of SD card to hard drive, it is important to do the importing in Premiere using MEDIA BROWSER and not the "File > Import" method. Media Browser is tabbed at the lower left of the Premiere interface. It "understands" the file structure of AVCHD content and typically provides much better results than the standard Import method.
Jeff Pulera
Safe Harbor Computers
Jan 6, 2015 4:22 PM UTC
Thanks, dragging a .mts file from the Media Browser onto the Timeframe went with a bang. The video now displays in the Program monitor.
One thing though is that Export does not list the .mts format. Is there a way to retain the same .mts format or other format that maintains the 60 frames/second frame rate?
Ivanhoe13
May 30, 2014 6:55 AM UTC
I was up against the same exact problem, but I finally figured this out (for myself anyway). Although copying the entire camera card or drive contents is a great idea, it was not enough for Premiere to be able to recognize the MTS clips from my Canon Vixia HFS20 cam. I'm on a Mac btw. So, what I did was I entered the Private folder, right-clicked the AVCHD file and chose "Show Package Contents". Then I did the same for the BDMV file that appeared. Once inside BDMV, I opened the Stream folder and then dragged the clips over to Premier's media browser. Once I put clips in a sequence, somehow it took a little while for the audio to assemble itself to the video (first only a few seconds of the audio could be heard, but it then "loaded" the rest). It then played and edited perfectly. I have not read all of the responses to the initial post, and so my apologies for any redundancies.
Apr 25, 2014 1:58 AM UTC
Can't load AVCHD/MTS into Premiere Pro CS5.5? Even though the latest version of Adobe Premiere Pro claims to support AVCHD/MTS/M2TS videos, you may not import all AVCHD (.mts) files to Premiere Pro CS5.5 for editing for different parameter settings. Here, you can convert MTS to Premiere Pro best editing video format via Acrok MTS Video Converter or Acrok MTS Converter for Mac.
As we know, Adobe Premiere Pro supported MOV, WMV, MPG, AVI, MP4 editing well, so we can transcode MTS/M2TS to these video format on Mac or Windows.
Steps:
1. Run MTS to Premiere Pro Converter, import AVCHD/MTS video from your computer or camera/camcorder
2. Click "Format" to choose output video format, here, you can choose "Editing Software" > "Premiere Pro WMV/Premiere ProMOV/Premiere ProMPG"
3. Start MTS to Premiere Pro video conversion
Jul 24, 2013 2:40 PM UTC
for some reason without the ext. mts.sfk there will be no sound for premiere ..i notice that some of my mts files with it work...
KeithHopkin
Mar 24, 2013 2:49 AM UTC
AHHHHH! This is so effed! I was in the middle of a big project on CS5 and had begun organizing MTS files in my project. Now I'm on CS6 on a different machine with an external drive hooked up. It's impossible for me to associate the MTS files in my Prroject because of this "Private" insanity.  So what am I supposed to do??!! Start OVER?!!!!!
Jeff Bellune
Mar 24, 2013 3:01 AM UTC
I recommend going back to CS5 until you finish your big project.  Then switch to CS6.  No starting over required.
Jeff
KeithHopkin
Mar 24, 2013 3:07 AM UTC
This is exactly what I was telling myself like 2 weeks ago - "Don't ever upgrade in the middle of a project". Ha.
Well what kind of also screwed me was the first 27" iMac I received a few weeks ago that arrived with a defective heat sensor (fans were blowing like crazy).
I was determined to start and complete this project on this new machine. I didn't get too far, just made initial selects on a a few shoot dates.. but man, this is just so typical of major software and OS upgrades. It seriously never ends with this stuff. I've experienced these types of things for years. It never ends and you need to always be ready to get screwed by these types of things.
Mar 18, 2012 9:48 PM UTC
Whats up guys, been a while since ive been on this post and it sure has many people talking. Anyways, a friend of mine has recently discovered a way to import the AVCHD (.mts) into Ppro, by selecting the AVCHD setting in Sequence presets, so the question is, where is mine?
Harm_Millaard
Mar 18, 2012 10:00 PM UTC
Looks like your installation reverted to trial mode.
One tedious but good solution is:
  • Deactivate if possible
  • Uninstall
  • Run Clean Script several times, rebooting after each run
  • Install
  • Activate
  • Update
