Importing Preset not working correctly for exporting clips from timeline as separate files
Hey guys have been going at this for about an hour. I saw the thread that explains how to export the timeline as individual files, one for each clip, but when I try I get a problem.
When I use the "Project Manager > Consolidate and Transcode > Individual Clips" everything works exactly as expected except I get huge file sizes. 200-300mb for 5-10 second clips each. The bitrate is set to 200mbps with this method on the lowest prores formats when I am aiming more for ~24mbps
To solve this I see you're supposed to go into media encoder, export a preset, and then import to premiere. However, when I try this I then get a completely different outcome. Using two different presets so far (the one I am currently trying is called "High Quality 1080p HD.epr") I no longer get the clips being saved as individual files.
Instead what happens is I get a folder with each clip name titled "clipname (1).movBDMV > STREAM > clipname (36).mov, clipname (36)_1.mov, clipname (36)_2.mov" and these three MOV files are not the actual clip but insted three copies of the original source which is 10-15 minutes long for each clip. The bitrate however seems correct with these.
Very confused on what I am doing wrong. I also tried doing the render and replace method but when I go that route I get an error saying "Transcode Failutre, unable to match audio channels"
