Nov 22, 2026 6:29 AM UTC
In Premiere Pro, when I nest a sequence with J/L cuts into a new sequence, the audio splits into separate tracks and some parts go missing, instead of coming in as one clip with one waveform.
I made J-cuts and L-cuts in a sequence called "Tight Cut 3" (video on V1, dialogue split across A1 and A2). I then wanted to put it inside a new sequence as one nested clip, with all the audio showing as a single waveform, like a normal nest.
What happens: when I drag the sequence into the new one, or create a new sequence from it, part of the content goes missing. The audio also comes in split across separate tracks (A1/A2) instead of one combined clip. I also get a "Tight Cut 3 [V]" clip with a white block at the start of V1.
What I expected: one nested clip with one waveform, with the J/L cut overlaps intact.
Notes:
  • This worked for me once before using the same method, but it doesn't work now.
  • The "Insert and Overwrite Sequences as Nests or Individual Clips" button is not enabled in my timeline.
  • I have two sequences with the same name, "Tight Cut 3".
  • Mac, latest Premiere Pro. The screen recording is attached.
PaulMurphyCorrect answer
Nov 22, 2026 8:52 AM UTC
It looks like the nested sequence was inserted with the start of the sequence trimmed, so you should be able to extend it. The white block is just a gap in your timeline that you've selected.
As for the audio breaking across A1 and A2, if you render the audio of the nested sequence in the main sequence, does the waveform display, and can you hear everything?
If not, please share a screenshot of the Audio Track Mixer for Tight Cut 3. Also select Tight Cut 3 in the Project panel, choose Clip > Modify > Audio Channels, and share a screenshot of that dialog.
Note: For nesting, the Insert and Overwrite Sequences as Nests or Individual Clips button should be enabled in the Timeline.
PaulMurphyCommunity ExpertCorrect answer
