Info window and opacity mask keyframe problem
I'm using Premiere Pro 2023
Version: 23.1
I can't doct the info window because it doesn't have the three bars things:
Trying to click and drag anywhere doesn't cause it to snap.
My second problem is that I can't copy and paste mask keyframes from the opacity in effects controls if the clip has different diemensions that the original one. Someone had a similar problem, but no one the solutions worked
