musaby
Input and Output Points Doesn't sync with my current values..
Okay me again with a weird annoying issue.
Pretty simple yet i dont even know how to search an answer for this.
So in my timeline i have input and outpoint points, so lets say the part i want to export is 30 sec long and when i want to export.. premiere pro does not sync with my current points value, he just only allow me to render first 16 sec of the timeline. I can manuelly change this issue in export page but it's annoying to set all frames correctly one by one. IDK what happened this is my first time i'm having this issue in 6 years 😕😕
Did i change a settings some how?
For Range, choose Source In/Out instead of Custom. That should work for you, @musaby. Let us know!
musaby
musabyAuthor
Yes, it worked, gosh it was so simple thank you for this Dear Kevin
