Jarrod Taylor
iPhone 12 Pro Dolby Vision HDR Export Solved
  • December 4, 2020
  • 4 replies
  • 16575 views
Sample Footage:
https://youtu.be/xQjX-VGM7MY
Ok finally after a month I've worked it out how to Export iPhone 12 Dolby Vision HDR projects in Premiere Pro and to save anymore tears for all of us 😂  1: Import your iPhone footage into Premiere Pro I'm currently using version 14.5 which you will need. 2: Set your sequence to match frame size, frame rate etc but the main thing we need to do is change "Working Color Space" to Rec 2100 HLG. iPhone Dolby Vision colour space is Rec 2020 HLG but this will work for now until they update Premiere. 3: Make sure when you color grade set your scopes to HDR and color space to Rec 2100 HLG. 4: Ok this is where I lost my mind for the last month but finally worked it out. For Export choose MXF OP1a Format Video Codec: XAVC QFHD Intra Class 300 Next go to HDR Graphics White (Nits) make sure this is 203 (75% HLG) which is standard. Tick Render at maximum depth, Enable Smart Rendering Codec, Hybrid Log Gamma, Use Maximum Render Quality. If your wanting to upload to YouTube or for a client this is the best and only option I've found that works with Premiere. I hope I've saved everyone from this headache.
Thank you very much for this! This was a huge help. Curious if you have tried exporting with Premiere v22? It seemed to me the default export setting for MXF OP1a Format Video Codec: XAVC QFHD Intra Class 300 works even though that shows HDR Graphics White (Nits) make sure this is 100 (63% HLG). I could be missing something and it still needs the extra steps.
Do you have any suggestions of how to use one of these clips in a mixed footage sequence?
Thanks again!
Brett
Jarrod Taylor
Hi Brett,
Glad to help. I havnt tried working with Dolby HDR footage in the new version of Premiere V.22 but hoping you can export out using H.265, fingers crossed.
As far as using the footage on a "Mixed Sequence" that is fine, but being the fact that it is mixed you cant use the Dolby HDR format using Rec 709 colour space etc. The Dolby HDR clip will be a standard Rec 709 clip.
When I try this, it comes out too red. It looks perfect in Premiere, in the preview and also if I import the mastered file back into Premiere. But if I export as a quicktime or if I upload the mxf file to YouTube, it comes out with over saturated red tones
Jarrod Taylor
You'll need to bring down the Reds when you Colour grade.
Worked great for me. Just don't really know what to do with the huge mxf file. How did you get it to something more manageable for the end consumer?
Jarrod Taylor
Yeah unfortunately the file size is large. Until they update Premiere where we can export to H.264 or H.265 in HDR this is the only option I've found that works.
Jarrod Taylor
