Ken Nielsen
iPhone 6/6 Plus Slow Motion 240fps Cinematic Camera .MOV clips do not play in slow motion in Premiere Pro - Need Help
  • June 30, 2015
  • 12154 views
I know there is an understanding that needs to be in place before accomplishing slow motion in Premiere Pro. I have clips that play in slow motion on the iPhone 6 just fine but when I open them in Premiere Pro 2015 CC they play as normal videos without slo motion. Can someone help me understand how to import and then get these clips to play properly in Premiere Pro?
TIA,
Ken
    Correct answer Thanos_Kamaretsos
    1. Try importing them as always
    2. Select the clip at the project window / right click / modify / interpret footage
    3. select your working frame rate (i.e 25fps)( instead of the file's frame rate )
    4. drag the clip back to the sequence
    hope this helps...
    Thanos_KamaretsosCorrect answer
    hope this helps...
    Ken Nielsen
    Thank You so much Thanos_Kamaretsos. This is an amazing insight to me and I need to contemplate what is really happening here but I can see that the footage is shot at 240 frames per second and then played at that same recorded speed is going to be just a very high frame rate but at normal speed. When I changed it to 29.97 fps then it played back at roughly one tenth of the recorded speed so much slower than it was recorded and at still a very smooth motion. I am very grateful for your reply.
    Thanks much Thanasis!!
