Is it possible to create a Multi-Cam Source Sequence in Premiere Pro using ExtendScript?
I am working on automating workflows in Adobe Premiere Pro using ExtendScript. I would like to programmatically create a multi-camera source sequence (multi-cam sequence) through scripting.
  • Is it possible to create a multi-cam source sequence using ExtendScript?
  • If yes, which API methods or objects should I use for this task?
  • If not supported directly, is there any alternative scripting approach or workaround to simulate or achieve multi-cam editing behavior through ExtendScript?
Bruce Bullis
Bruce BullisCorrect answer
Only by cloning an existing multicam sequence.
> Is there any alternative scripting approach or workaround to simulate or achieve multi-cam
No.
You're not the first person to request such APIs, but any API expansion/improvement will need to wait until we officially release UXP extensibility, in PPro.
Bruce Bullis
No.
Thank You @Bruce Bullis
