Is there a way can modify read-only components in Adobe-CEP?
  • March 6, 2023
  • 937 views
I'm a beginner writing some code through Adobe-CEP.
I select a clip on a particular video track to configure a code that changes the text inside the clip.
I've succeeded in choosing a graphic clip for subtitles.
Through [targetClip.components], I checked that the contents of the clip contain the text I want to modify in the item "instanceName".
Like {"displayName":"text", "instanceName":"subtitle"}
So I tried to modify the "instanceName"'s value, but it seems that direct modification is not possible because the components are read-only items.
Is there any way to correct this?
Correct answer Bruce Bullis
>Is it possible to modify the contents of the regular text component, not the .mogrt?
There is no API that provides that functionality.
Bruce Bullis
Confirming: Your goal is to change the text within an application of a .mogrt, yes?
If so...
You'll need to check that the trackItem is actually from a .mogrt. Here's how PProPanel does that:
https://github.com/Adobe-CEP/Samples/blob/e60d6a22ef44d8eb4cca3904c35a0c050576b697/PProPanel/jsx/PPRO/Premiere.jsx#L1884
Even then, it will only be possible to modify parameter streams that the .mogrt author declared as modifiable.
Thank you very much for your reply
I added text using the "text tool" inside the Premier Pro without using other external mogrt and created a subtitle clip with effects such as shadow.
After that, I would like to change the contents of the text description component inside the subtitle clip through Adobe-CEP, is there any way?
I can select that clip and can select text component but text component's value is not description but font. text description i want change is in components[i].instanceName.
Bruce Bullis
Bruce BullisCommunity ManagerCorrect answer
